96 S10 and 97 S10 Engine Harness and ECM - S-10 Forum
post #1 of 13 Old 02-07-2010, 11:05 AM Thread Starter
V8Sonoma96's Avatar
User is: V8Sonoma96 is offline
I have 96 S10 without a motor and harness. I'm doing V8 swap and found harness and ECM for 97 S10.
What I see from wiring is that ABS is different from 96 to 97 year. Does anyone know how the ABS is controlled on 97 S10.
post #2 of 13 Old 02-19-2010, 04:35 PM
User is: Atilla the Fun is offline
Re: 96 S10 and 97 S10 Engine Harness and ECM
No S-10 ECM is going to control any V8. GM never sold any V8 S-10s. The best was a 4.3L V6. Look at the V6 distributor, then look at the V8 distributor. See any differences? There ya go.
post #3 of 13 Old 02-21-2010, 12:33 AM Thread Starter
V8Sonoma96's Avatar
I know they never sold with V8. I'm doing a swap. LOL
Does anyone know about ABS difference on years 96 > 97?
post #4 of 13 Old 07-29-2010, 12:31 AM
User is: Stephon Garnett is offline
o dont know the ABS for the 96-97 man. anyway, just interested about the swap. Were you able to do the swap already?thanks and have a good day!
_____________
SG
upgraded my chevy s10 parts
post #5 of 13 Old 07-29-2010, 08:32 AM
the youngest has been
tippmann243's Avatar
User is: tippmann243 is offline
this is the biggest line of bullshit i have ever heard.
im using a 2001 s10 blazer pcm to control my 98 c3500 truck motor
the same computer can also be used to control the LS series of motors
-mark
89 s10 blazer 5.7 vortec/t56 0411 pcm powered
03 zr2 s10 with some mods
post #6 of 13 Old 07-29-2010, 10:08 PM
User is: the_dam_man is offline
yeah on my 97 computer I can go in with my Jet tuner and just change the cylinder count....done.
post #7 of 13 Old 08-02-2010, 09:00 PM
User is: Ssuperman is offline
Read this. 96-97.
http://www.currentperformance.com/s10wir.html
post #8 of 13 Old 08-02-2010, 10:00 PM
Heavy Metal Body Man
Maverick2664's Avatar
User is: Maverick2664 is offline
Send a message via AIM to Maverick2664
this is completely false, like tippman said, around 99-02 s10's used the 12200411 pcm to power them, which is THE SAME pcm used for the v8 vortec trucks and vans as well as the LS1's in the camaros and vettes... not only that the earlier 4.3 ecm in the s10's has been very successfully used to power the TBI 350s with little effort
next time know what youre talking about before being a cocky smartass, because you look like an idiot when youre wrong
-Under Construction-
98 S-10 extended cab: stock floor body drop, TPI 383 w/ 0411 pcm conversion, T56 manual
post #9 of 13 Old 11-02-2010, 08:11 PM Thread Starter
V8Sonoma96's Avatar
Still trying to find the info. I already programmed the pcm to run v8
post #10 of 13 Old 11-02-2010, 11:20 PM
there is a great write up on here for how to repin the harness. pretty simple stuff (I am in the middle of it right now)
post #11 of 13 Old 11-03-2010, 07:40 PM Thread Starter
V8Sonoma96's Avatar
^Are you talking about pinning the harness to V8 or how to repin the harness for 97 truck?
Do you have a link?
post #12 of 13 Old 11-11-2010, 06:05 PM
User is: BLLaZZR is offline
the 96 ABS is built in to the PCM i think, there is a separate module used to control ABS on 97 and newer.
if you want to use a 97 s10 harness you will need the injector pod(assuming your swap is fuel injected) from a V8 1500 harness and change a few pins at the PCM for the v8 configuration. I did it on my 96 blazer with a vortec 5.0l fuel injected, it works.
BLLaZZR is offline
post #13 of 13 Old 11-11-2010, 08:37 PM Thread Starter
V8Sonoma96's Avatar
I wanted the ABS to work so I end up getting 96 harness.
