96 4.3 to 5.7 swap questions - S-10 Forum
post #1 of 11 Old 03-25-2008, 10:23 PM Thread Starter
anyone want to help?
ntloenf's Avatar
User is: ntloenf is offline
I have a 96 s10 with a 4.3. i also have a 5.7 out of a 97 fullsize truck that will be using. I have the jtr motor mounts and patriot headers as well for the swap.
my questions are:
1. Am I better off trying to keep my vortec 5.7 fuel injected or should i just carb it as fuel economy for the truck is not a major concern?
2. If i keep it fuel injected, I believe i need the computer from the 5.7, and what else do i need to do to wire/plum it?
3. If i go with a carb setup, how big of carb should i run? also what do i need to do to wire/plumb it? and do i need the 4.3 computer for this setup?
any help is appreciated. i dont really need a step by step how to but even if I can get a general idea. get me headed in the right direction.
ntloenf is offline
post #2 of 11 Old 03-26-2008, 03:33 PM
cool to the tool
shiftit's Avatar
User is: shiftit is offline
Re: 96 4.3 to 5.7 swap questions
if your 4.3 and 5.7 are both the "spider" injection (1 injector for each cylinder) you should only need to add 2 wires for the extra injectors and change a few things on the pinouts at the computer. You can subscribe to ACDelco and get the wiring diagrams for both vehicles for about $20, well worth it.
if both vehicles have 4l60e's the tranny wiring shouldnt need any modding (i think)
Originally Posted by droppedss View Post
Yes he has a e-report with the e-police and they have an e-investigation. They will e-arrest you and you will be in e-jail and will have to pay an e-bond to get outta e-jail. Then you will have e-court and a e-hearing.
Originally Posted by Imperial View Post
e-prisonrape
shiftit is offline
post #3 of 11 Old 03-26-2008, 06:22 PM
bkaltec's Avatar
User is: bkaltec is offline
Youve got a super easy swap on your hands. The 5.7 will swap in no problems. Fuel lines will hook right up. The v6 engine wire harness will work on the v8, but, you will need the v8 fuel injector plug. And weave/solder in the (4 total, 2+ 2-) extra wires for the fuel injectors. Youll need the wire diagrams to do this to setup the correct pins. It gets a little tricky with the 96 trucks because the abs is computer controled that year. So you can either try to use the v6 computer and have it reprogramed, ive never done this so couldnt give any insight on it. Or use an abs module from a 95 blazer, which is stand alone. You also have the option of removing the abs all together. All guages and functions of the truck will remain the same. Trany, driveshaft and rear will all work with the v8, no mods. I would recommend using a corvette radiator, late 80's model and in the foward position (inside the radiator support. And electric fan. Also, sell the v8 swap manual while you can, theres realy not a lot of info in there for 2nd gen trucks. If you have any doubts, think of the vortec v8 as a vortec v6, its pretty much the same thing.
bkaltec is offline
post #4 of 11 Old 03-26-2008, 10:31 PM Thread Starter
ntloenf's Avatar
thanks for the information. have you done the swap yourself or not? also could i just get the computer from the 5.7 and plug in the connector? that way i wouldn't need to solder in wire? just wondering. oh and i plan on ditching the abs. let me know please
ntloenf is offline
post #5 of 11 Old 03-26-2008, 11:14 PM
User is: ominus is offline
I have a side question, not to steal your post from ya.
I have a 95 4.3 4x4 tbi....would this swap be fairly easy into my truck as well, or would it be a bit of a bitch?
Would I just have to get the ecu and harness from another s10 or from a v8 donor truck or would there be more too it?
ominus is offline
post #6 of 11 Old 03-27-2008, 02:26 AM
cool to the tool
shiftit's Avatar
I did this swap in my 98 blazer, slightly different but same basic idea. if you got the whole harness from the 5.7, you need two (-) wires running from the injector harness on the intake to the computer, than you can piggyback off the pink hotwires that are there from the other cylinders.
97's had a 5th connector for abs. so just leave it disconnected and you should be fine.
e-prisonrape
shiftit is offline
post #7 of 11 Old 03-27-2008, 02:27 AM
cool to the tool
shiftit's Avatar
it would be a pain if the 5.7 was cspi. if the new engine was also tbi it is fairly easy but i dont know what exactly needs to be done.
e-prisonrape
shiftit is offline
post #8 of 11 Old 03-29-2008, 11:31 PM
humm...what are my best options for finding a 5.7? I have look around here abit, at wrecking yards and what not....but I am not sure what all had the 5.7
ominus is offline
post #9 of 11 Old 03-30-2008, 12:17 PM
cool to the tool
shiftit's Avatar
full size chevy & gmc trucks like the 96-99 c1500 and k1500
chevy tahoe same years
those are a couple to get you started.
e-prisonrape
shiftit is offline
post #10 of 11 Old 03-30-2008, 03:00 PM
User is: 9743blzr is offline
my questions are:
This is by far one of the easier swaps and cheaper swaps. The 4.3 and the 5.7 are one in the same. It is much easier to junkyard up the motor and computer, and get the wiring diagrams for the extra two cylinders needed. The majority of parts are interchange for the most part.
9743blzr is offline
post #11 of 11 Old 03-30-2008, 09:24 PM
"Phat"boy
Jamal's Avatar
User is: Jamal is offline
2500 GM vans had the 5.7
"Hard work often pays off over time, but laziness pays off now!"
"everyone has the right to be stupid, some just abuse the privilege"
Jamal is offline
