91 sonoma questions
well guys im a noob at the engine swap thing. I have read alot of info on this and still have some questions.
first ill start with the truck is a 91 sonoma SL. 2.5L(carbed) automatic. the motor has a very bad knock but still runs. I paid $300 for it. Body seems to be PERFECT. no rust, no dents. well except for the front bumper. please keep in mind this wil be a daily driver/ fun truck. i need it dependable but still be able to kick some ass and look good for some shows. plans are a 350/th350 combo. 540 lift cam, edelbrock carm and intake. keeping the p/s and a/c. corvette Nassau blue with black C6 corvette motorsport wheels. after the v8 swap it will be time for a early dash swap/autometer gauges and a custom gauge panel. Im an aircraft sheetmetal mechanic so i have some crazy ideas. anyways my questions are basic but i just need a straight answer. I have looked and read some on all these questions but i just want a straight answer as i don't want to waste time. 1. after reading the motor mount thread im am totally confused on what to get. do the plaste mounts he gave plans for mount to the frame, 4.3L mounts, or 2.8L mounts? what works best 2. How hard will the electrical be to convert to get teh v8 to run and not throw an engine light?. Im keeping the abs (if it has it) and all the stock radio/gauges for now. 3. Will it be better to do the dash swap and autometer gauges while doing the v8 swap or after? 4. has anyone ever used the stock colume shifter with a v8 swap? how hard is it or should i just go with lokar? 5. what trans crossmember did you guys use or did you have to make one. 6. VERY soon after the v8 swap but before anything else i want to upgrade the brakes. I would like to do some new z06 brakes in the front and a clean looking disk set up in the back. 7. what stall should i get for a cam with 540-560 lift? i can get better cam specs if needed. 8. the stock rear wont hold up for long so what do you guys reccomend i replace it with? i want something that has disk brakes and I dont have to change my wheels due to the with difference. 9. anyone ever done a early model dash swap? How hard is it and what is needed from the older model truck? Will the later heater ductswork? what about the metal dash bar? 10. what drop will look good. I want it a little lowered but not too much because of the pot holes here in oklahoma. I was thinking a 3/3 or 3/4. it will still have a nice agressive look and still be able to haul a small load with no problems. im sorry for the noob questions guys. I just want a straight answer with no bs. If someone has asked these exact questions before, feel free just to post the link where the info can be easily found. thanks in advance, mike in choctaw p.s. the red one is the 91. the gold one is my partial restored 83 4x4 tahoe package. |
Re: 91 sonoma questions
anyone?
Local Tech
bro, that is way too much stuff to ask in one post..... if ur truck is carbed now, the wiring is not a big deal..... u should be able to keep ur stock gauges if u want..... not sure bout the trans x-member.... get 2.8 mounts, the 4.3's are too soft..... for a rear, u can get an explorer rear (they have discs, and there are many install threads on it)..... or an 8.5 from a 2wd blazer with discs (MUCH MORE EXPENSIVE) you can use the column shift if you want, but itll make header/steering clearance tighter.... as of the rest, work on one project at a time
hope i was some help...... good luck |
All up in your shit
Location: Lakeville, MN User is: OffLine ![]() ![]() ![]() ![]() ![]() |
http://www.s10forum.com/forum/f30/ja...roject-325904/ Last edited by jakethegriff : 08-07-2008 at 12:01 PM. |
what rad and electric fan are you running. the truck won't necessarily be a daily but it will ger driven a lot. ill get the info on the cam and see what stall i need. I hope to have it at least running in the next month or two. |
All up in your shit
i'm running the summit racing s-10 v8 swap aluminum radiator and dual 12" flex-a-lite pullers
i need an honest opinion. Out of these 2 wheels. what one should I run. Im torn between the 2. im leaning toward the c6 wheels. 18x8.5 & 18x10.5 C6 corvette motorsport wheels or 20x8.5 KMC 701 Nova wheels. |
All up in your shit
http://store.summitracing.com/partde...5&autoview=sku radiator- http://store.summitracing.com/partde...0&autoview=sku |
thanks for the part numbers. Motor just got delivered about 2 hours ago. 355 with a .525 lift cam. stock heads for now. edelbrock 600cfm carb and rpm intake. paid $250 for the motor and had all new bearings and rings installed. The guy who built it picked it up last night and has it done for me in 12 hours. he didnt sleep and he is a bad ass engine builder so i know its right. it does have a mechanical pump. would that be better to use than a electrical one. |
All up in your shit
Np. I personally like mechanical pumps, as opposed to the stock electricals, just one more electrical item to worry about IMO. But like i said you'll get mixed opinions on this topic, it's all about personal preference.
