700r4 vs. 4L60E - S-10 Forum
post #1 of 33 Old 02-22-2008, 01:10 PM Thread Starter
User is: therule546 is offline
700r4 vs. 4L60E
What is the difference between the two. I read through the swap post at the top and there were 4-5 different explainations. What is the difference between the two? Will both work with the stock automatic floor shifter thats in my truck?
post #2 of 33 Old 02-22-2008, 02:12 PM
Bored as hell
Petterle's Avatar
User is: Petterle is offline
Send a message via AIM to Petterle
Re: 700r4 vs. 4L60E
4l60e is eletronicly controled and has 4 speeds 700r4 is a 3 speed with overdrive and has a low first gear
-Josh-
1993 Chevy 2500 350/4L80E 4.10s. New daily.
1988 Chevy 2500 350/700R4 4x4 SC/LB. RETIRED.
Petterle is offline
post #3 of 33 Old 02-22-2008, 02:25 PM Thread Starter
Re: 700r4 vs. 4L60E
is the 700r4 computer controlled as well?
post #4 of 33 Old 02-22-2008, 02:41 PM
4.3 FlexFuel E85 :-)
User is: MoonDogg is offline
Re: 700r4 vs. 4L60E
A 4L60E is a 700R4 just computer controlled. The only difference is the power handeling abilitys of the ones that came on v6's and the ones that came on v8's and thats for both models.
2000 S10 Ext. Cab 4.3 5spd
MoonDogg is offline
post #5 of 33 Old 02-22-2008, 04:07 PM Thread Starter
Re: 700r4 vs. 4L60E
So would a 700r4 swap in just fine with a vortech 5.7L? and would it still work with the stock floor shifter in the truck? The more i read about this the more confused im getting. How do i know what tranny i have right now?
post #6 of 33 Old 02-22-2008, 05:34 PM
Bored as hell
Petterle's Avatar
Re: 700r4 vs. 4L60E
a 5.7 and a 700r4 should be fine, ive heard stories that the 700 is weak but in my experiances they were bulletproof, as for the floor shifter im not sure
-Josh-
Petterle is offline
post #7 of 33 Old 02-22-2008, 06:23 PM Thread Starter
Re: 700r4 vs. 4L60E
Is it normal for a 97 ex cab p/u to have the shifter on the floor in an automatic?
post #8 of 33 Old 02-22-2008, 07:29 PM
acgreaser05's Avatar
User is: acgreaser05 is offline
Re: 700r4 vs. 4L60E
Man they put these trucks together so many different ways, with so many different parts, is the truck 2wd?
...and what motor came in it?
94' regular cab, custom paint, 18's, bagged, cut through ,custom interior, 4 link, stay tuned for v8
99' black Jimmy 4x4 fully loaded
post #9 of 33 Old 02-22-2008, 08:05 PM
Bored as hell
Petterle's Avatar
Re: 700r4 vs. 4L60E
auto's are usually colum shifted, i have seen blazer autos with floor shifters though. i have never seen a floor shifter in an s10 unless its a stick
-Josh-
Petterle is offline
post #10 of 33 Old 02-23-2008, 05:50 AM
An ol Scott
SilverWings's Avatar
User is: SilverWings is offline
Re: 700r4 vs. 4L60E
I have seen automatic Sonoma's with a factory installed floor shifter but not any S10's as of yet. Not that there isn't though. Thats just something I haven't run across.
Go with the 700r4. It will out last a stock 4L60E by a long shot.
95 standard cab 4.5/2 drop, all Beltech with UMI Proformance A arms with tall balljoints, Wilwood disk brakes. Energy Suspension polys, heavy duty anti sway bars front and rear, Richmond Gear locker rear with a 3.08 gear, a 300+ hp LT1 Vett and a 4L60E with Vett internals and Vett converter. HID head light upgrade and various LED lighting.
My (still, less than exciting, even after updating it) Cardomain site
http://www.cardomain.com/ride/856839
post #11 of 33 Old 02-23-2008, 11:12 AM
LSx and V8 Mod
SweetS10V8's Avatar
User is: SweetS10V8 is offline
Send a message via AIM to SweetS10V8
Re: 700r4 vs. 4L60E
I disagree, the 4L60 is computer controlled the 700r4 is just a mechanical piece that doesn't adjust if something changes.
4L60s are a part of GMs 100k mile warranty. Back (pre 93) when 700r4s were prevalent, I bet the drive line had the 36k mile warranty.
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
post #12 of 33 Old 02-23-2008, 01:28 PM
bigjoe1015's Avatar
User is: bigjoe1015 is offline
Re: 700r4 vs. 4L60E
You are correct, sir!
Besides, if the 700R4 was so superior, they wouldn't have added more electronics to it. They added them to it to increase its longevity, and so that it would communicate with the PCM so that it did exactly what it was supposed to WHEN it was supposed to.
"I hope if dogs ever take over the world, and they choose a king, they don't just go by size, because I bet there are some Chihuahuas with some good ideas." -Jack Handey
My V-8 Swap: (finally done!)
http://www.s10forum.com/forum/f10/94...g-gear-337756/
post #13 of 33 Old 02-24-2008, 11:20 AM
stuck static
lowxpectationz20's Avatar
User is: lowxpectationz20 is offline
Send a message via AIM to lowxpectationz20
Re: 700r4 vs. 4L60E
I have! 97 is the only year they came! A kid on ohio mini trucks, named noma97 had one!
OldSchoolSdime92-aim
troy ohio(north of dayton)
Quote: Originally Posted by suicidedoors.com
you didnt void the warranty. at the moment i cant think of anything you can do to void the warranty.
post #14 of 33 Old 02-24-2008, 12:14 PM
85smallblock's Avatar
User is: 85smallblock is offline
Send a message via MSN to 85smallblock
Re: 700r4 vs. 4L60E
4l60e for the win. basically a 700r4 with a computer controlled valve body. the best thing about the 4l60e is you can program it to shift harder and at whatever points you want
and since you are running a vortec,it already came with a 4l60e. so the vortec computer will operate the trans
-85' std cab sb lowered 5-6 16" GTA wheels. 295-50-16 rear 215-55-16 front, 305 tpi v8,700r4 stage 2 shift kit,tci 2000rpm stall,hedman elite shorties,jegs 2.5" true dual mandrel bent exhaust kit,
in progress............. Project Thread
SOLD
-92' TEAL BLUE s10 BLAZER 4X4 4DOOR 4.3 TBI. LOADED. GETTING LOWERED WITH 95' Z28 WHEELS SOON
post #15 of 33 Old 02-24-2008, 05:10 PM
stuck static
Re: 700r4 vs. 4L60E
so if ive got a 4l60e in my blazer, and i want to swap over to a 350, it shouldnt be an issue?
post #16 of 33 Old 02-24-2008, 09:24 PM
Re: 700r4 vs. 4L60E
your engine light will stay on. it might run different without getting info from the trans.
SOLD
post #17 of 33 Old 02-24-2008, 09:57 PM
L98 Blazer
j_slezak187's Avatar
User is: j_slezak187 is offline
Send a message via AIM to j_slezak187
Re: 700r4 vs. 4L60E
like only reverse....no forward gears. the 4L60E needs all the PCM inputs to function correctly.
-'87 S10 Blazer, 355 TPI/700R4
-'02 ZR2 Daily Driver
my CarDomain
post #18 of 33 Old 02-24-2008, 10:04 PM
Stepsides are cool
xxannihilationx's Avatar
User is: xxannihilationx is offline
Send a message via AIM to xxannihilationx
Re: 700r4 vs. 4L60E
i have an automatic floor shifter too. its pretty badass, because im not a big fan of column shifters
post #19 of 33 Old 02-26-2008, 12:12 PM
stuck static
Re: 700r4 vs. 4L60E
so my 4l60e, in my cpi 4.3 blazer will work on a for example tbi 350? TCI makes a 4l60e controller so your able to run it on a carbed application also. But is the 4l60e different from the v6 to a v8?
post #20 of 33 Old 02-29-2008, 11:16 AM
L98 Blazer
Re: 700r4 vs. 4L60E
if you are staying with TBI, then you can go with the '427 PCM that came in the last gen TBI trucks. they have all the outputs for the 4L60E.
my CarDomain
post #21 of 33 Old 02-29-2008, 01:40 PM
Banned
User is: 4x4zr2GA is offline
Send a message via AIM to 4x4zr2GA
Re: 700r4 vs. 4L60E
4L60E is the same no matter what. v6's and v8 trucks had the same dang 4L60E. its a strong tranny. i just had mine built with the stongest parts you could buy, plus corvette servo's and a B&M shift kit.
4x4zr2GA is offline
post #22 of 33 Old 02-29-2008, 02:40 PM
User is: caftan is offline
Re: 700r4 vs. 4L60E
I use a 700r4 behind my vortech with no problems, but everyone's setup and
variations will be the deciding factor on which one is best for you.
caftan is offline
post #23 of 33 Old 02-29-2008, 10:01 PM
the youngest has been
tippmann243's Avatar
User is: tippmann243 is offline
Re: 700r4 vs. 4L60E
this is not ture. there is a different number of clutch pack inside the trans for 4 cyl to v6 to v8
-mark
89 s10 blazer 5.7 vortec/t56 0411 pcm powered
03 zr2 s10 with some mods
post #24 of 33 Old 03-01-2008, 06:34 PM
User is: mrholley_3997 is offline
Re: 700r4 vs. 4L60E
I'm a GM tech. so lets clear this up. GM has a 4L60,70 and 80. they changed the code rpo numbers in the late 80s. IT IS THE SAME TRANS with the additions of servos and electronics thats why the "e" is on the end.Later 4L60s will not work with out an ECM of the same year due to TPS and RPM feedback.You cant run this trans without a TPS. If your truck is caburated then go with the 700r4. you'll have less problems.And about durabilty, I'd worry more about the factory rear end cause you'll grenade it long before the trans.
post #25 of 33 Old 03-01-2008, 06:38 PM
Re: 700r4 vs. 4L60E
also rember that 4L60Es 92 AND UP HAVE ELECTRONIC SPEEDODMETER FEEDBACK NOT THE OLD CABLE
post #26 of 33 Old 03-01-2008, 06:54 PM
An ol Scott
Re: 700r4 vs. 4L60E
Then my personal experrience with a rebuilt and mildy hot rodded 4L60E was an abnormal one. It did'nt last a year and I wasn't racing it every weekend all year long.
I'm getting ready to install a GM 350 RamJet Crate engine and a decission about what trasmission to use is the next thing to deside on.
post #27 of 33 Old 03-01-2008, 06:58 PM
An ol Scott
Re: 700r4 vs. 4L60E
Then which one would you suggest I use behind my 350 RamJet?
post #28 of 33 Old 03-01-2008, 07:39 PM
Re: 700r4 vs. 4L60E
good try
but 89 was the first year for the electric speedometer
-mark
post #29 of 33 Old 03-01-2008, 07:39 PM
Re: 700r4 vs. 4L60E
4l80e and call it done
-mark
post #30 of 33 Old 03-02-2008, 02:39 AM
stuck static
Re: 700r4 vs. 4L60E
well I plan on swapping the cpi 4.3 out once it decides to call it quits for a tbi 350. no one has yet given me a straight answer if the 4l60e I have now will work. One guy said if i use a certain pcm, and another guy said its got different clutch packs. so whats the overall thought on doing this?
post #31 of 33 Old 03-02-2008, 10:01 PM
Re: 700r4 vs. 4L60E
yes it will work as long ay you get a tbi wiring harness and ecu from the same year truck.
there is a different number of clutch packs but thats just limits the power that it will handle.
-mark
post #32 of 33 Old 03-03-2008, 04:49 PM
User is: umpyre32 is offline
Re: 700r4 vs. 4L60E
I am going to use the same motor when I make my swap(looking for right truck). Everything I have read points me towards a 700R. The Ram Jet will come with it's own computer which I think bolts to the firewall. I'm just "Old School" and want less electronics. TCI and B&M both have 700R's from $1400---$2200 depending on what you want. The Ram Jet you are talking about is 350hp and both make good trannys for up to 450hp. If your S10 has a V6, from what I have read, you can reuse the electrical harness for altern, AC etc. You may have an issue when you get it inspected. Not sure how O2 sensors will work. I'm sure there is a way to solve this, just haven't gotten that far.
UMP
umpyre32 is offline
post #33 of 33 Old 03-03-2008, 11:35 PM
User is: Jason383 is offline
Re: 700r4 vs. 4L60E
Are you stuck on four speeds? Yes from street driving it is nice but a 2 or three is better on the track. I'm just finishing up my th350b tranni. it is now bullet proof and the total cost was only $700!!! New TCI low-reverse roller clutch, Full b$m trans pak, all new thrust washers, All new bushings, and of course a complete seal and gasket kit. the only problem is there is some maching involved. the pistons on the low-reverse, forward, direct and intermeditate clutches can be machine a lot to fit more clutches. I have a 4-6-6-6 combo right now. better than the orginal 3-4-5-4. it should be able to stand up to 500 hp easy. at least i hope. my tranni before last exploded literally when i threw the forward clutch through the side of the tranni. amazing feat to be honest. Now if you are stuck on a 4 speed the 4l80e is your best bet. strong as hell and it should work with the computer for that vortec. the ramjet i am not sure about though. it should be able to be adapted though. hell just use switchs to control the two shift solenoids lol. possible.
Jason383 is offline
