700r to a 350 turbo
Old 10-11-2009, 07:09 PM   #1
fourwheeler75's Avatar
700r to a 350 turbo
i have just swapped my 700r for a brand new 350 turbo.... i was wondering about the drive shaft i know the 700r one will not work. but i was not sure if there was one i could get out of something else that would bolt in or if it was just easier to go have one made any kind of advice would help thank you .
Old 10-12-2009, 12:08 AM   #2
Revolt's Avatar
Re: 700r to a 350 turbo
I've seen 700 to 350 direct swaps, depends on the tailshaft.
Old 10-12-2009, 01:45 AM   #3
Former S10 enthusiast
01cherryreds10's Avatar
Try and put the driveshaft in. I put an 8.5" rear in my car and needed to shorten it 1" but we went with 1.5". The shaft was out of balance so they just made a new one instead. Your best bet is to just try and put it in with the truck on jack stands in the back on the frame.
Old 10-12-2009, 01:58 AM   #4
Revolt's Avatar
Also like to add, it depends on your engine mount adjustment.
Old 10-12-2009, 11:17 AM   #5
Registered Neanderthal
SH-60B's Avatar
I don't know of a bolt in. I had to get one made for the 350 transmission. The original shaft with the 2.8/700R fit the 5.7/700R
Old 10-12-2009, 02:49 PM   #6
Revolt's Avatar
If the 350 has a 9 inch or so tailshaft, it would only be 1/8 inch smaller than the 700r4. You can cheat and make that work with the existing driveshaft.
You probably would have to move the transmember.
Old 10-12-2009, 05:37 PM   #7
Probably take a dremel or a drill bit and elongate the holes for the trans crossmember if you were really concerned about that 1/8 of an inch.
Page generated in 0.56289 seconds with 31 queries
[Output: 59.16 Kb. compressed to 55.75 Kb. by saving 3.42 Kb. (5.78%)]
