454 radiator
Old 07-02-2009, 07:29 PM   #1
454 radiator
Well I got my 97 extended cab body on my 71 k5 frame offroad rig and working at getting a radiator for it now. I have seen a bunch of v8 conversion rads on ebay and stores. The radiator will go in front of the core support and the electric fans will go in the support were the condenser once was. Anyone have exoerience with any radiator and how well it kept engines cool? We put a 96 mini blazer body on a friends 94 straight axled fullsize rig with a 350 and did the same thing, put the radiator in front of support and behind the grill. The stock s10 radiator in it so far is keeping it cool but am afraind wont be enough for a mild built big block. Any input? Thanks, here is a pic of the overall rig so far, about to start bending tube to built the rear section.
Old 07-06-2009, 12:53 AM   #2
Slightly Over Built
DieselS10's Avatar
Re: 454 radiator
That's a cool truck!
I'm running an aluminum dual flat core 31X19 radiator that I bought on Ebay. It has managed to keep my 6.5 turbo diesel cool while towing trailers with it at near 100* heat, so I believe it would cool your BBC fine as well. I'm running the factory engine driven fan with a shroud I made though. I didn't trust electric fans with the diesel.
Old 08-18-2009, 08:56 PM   #3
Re: 454 radiator
Well I ordered one of these
http://www.summitracing.com/parts/GRI-1-55272-X
hope it cools the 454 ok.
Old 08-18-2009, 11:21 PM   #4
Slightly Over Built
DieselS10's Avatar
Re: 454 radiator
That one has the same dimensions and core design as mine. It requires a litle bit of core support mods though.
Old 08-18-2009, 11:33 PM   #5
Re: 454 radiator
the radiator is going to go in front of the core support and the electric fans will go in the support were the condenser was.
Old 08-18-2009, 11:37 PM   #6
Slightly Over Built
DieselS10's Avatar
Re: 454 radiator
Gotcha.
Are there any video's of that beast in action?
Old 08-18-2009, 11:39 PM   #7
Re: 454 radiator
Not in this configuration. Here is the build thread:
http://www.pirate4x4.com/forum/showthread.php?t=776907
Need to get radiator in so I can mount front winch and finish tube work and plumb in brakes and fuel yet.
Old 09-15-2009, 09:14 PM   #8
Re: 454 radiator
Got it in. Had to build mounts off front of core support to grab bottom of radiator. It clears the from by about 1/4" and I had to clearance hood for the radiator cap. I also had to trim the very edge of the headlight mounts just like 1/8" or so. The lower hose goes under the support and I notched it open a little more and the upper hose goes through the support. This is a dual 1.25" row 31x19 Griffin radiator. Also mounted the fans in the core support where the condenser would normally go.
Old 09-15-2009, 11:02 PM   #9
Slightly Over Built
DieselS10's Avatar
Re: 454 radiator
Glad it worked out.
BTW, I read through your Pirate thread, Very nice work!
Page generated in 0.61947 seconds with 31 queries
[Output: 66.44 Kb. compressed to 62.35 Kb. by saving 4.09 Kb. (6.16%)]
