4 core rad to thick?
Old 06-25-2009, 12:20 AM   #1
so i swapped my 1st gen to a 350 5 speed. i threw a 4 core copper rad into it though, almost perfect fit.
i have a plastic flex fan on the water pump, and a electric fan on it, but i am still overheating easily, going to mcdonalds drive through overheats me
160f thermostat, holley 750 dp proform center 69 72 jets, 292 .488 cam
any ideas guys? i changed caps, i have a 15 psi cap on it.
i dont have a/c, and removed the rad for it.
im about to put a aluminum 2 core 4.3l radiator in it, i think im not getting enough airflow for the 4 core
Old 06-25-2009, 05:44 PM   #2
takes 2 balls in our game
s10-den's Avatar
Re: 4 core rad to thick?
You can have the biggest radiator in the world in it, if you dont have enough airflow going THROUGH it, not around it, you will over heat.
Old 06-25-2009, 05:51 PM   #3
thats what i was thinking after i drove it, i need to switch it, or i was
i was offered today, even with the bad transmission, no wheels $3000
Old 06-25-2009, 08:28 PM   #4
Banned
probly overheating becuase you have a pusher and a puller fan... i treid that on my s10, had a pusher fan up front, and the stock clutch fan with shroud, it would overheat quicker than with just the stock clutch fan.
Old 06-25-2009, 09:02 PM   #5
hows that make any sense? one would assume it would run cooler, atleast it does on my fathers race truck
Old 06-25-2009, 10:24 PM   #6
mabru's Avatar
Do you have a fan shroud? Makes a big difference, helps direct the air flow. Also I've heard adding water wetter to the coolant helps to....haven't used it first hand though.
Old 06-25-2009, 10:38 PM   #7
Does NOT Work For CIA
Prostreet10's Avatar
Pullers work way better than pushers the air has to come through when the fans are pulling. On mine I bet 40% of air flow goes around radiator at least that what it feels like to me, I will be switching to pullers soon once i cut core support so i can move radiator forward a tick or two.
Old 06-25-2009, 10:38 PM   #8
Local Tech
ls1s10onair's Avatar
im with s10-den.... so many people dont understand that its the amount of air capable of passing thru the rad that counts.... not its coolant capacity, etc etc.... thats why so many vehicles have thin radiators. also, depending on how many fins per inch it has, its easier to get clogged, and thusforth, air cannot pass thru
Old 06-25-2009, 10:52 PM   #9
yes
i know its not clogged.
probably 6-8 fines per inch
Old 06-26-2009, 08:19 AM   #10
s10-den's Avatar
6-8 fins per inch !?
Old 06-26-2009, 10:17 AM   #11
the youngest has been
tippmann243's Avatar
if it has 6-8 fins per inch you should be able to stick a pencil through the fins and not bend them
stock 4.3 radiator is 12-14 FPI
aftermarket HD 4.3 radiaotr is 14-16 FPI
corvette rad is 14-16 FPI
just going off memory on the above counts. if they are incorrect please correct me
Old 06-26-2009, 03:12 PM   #12
s10-den's Avatar
I know what it means,I was saying thats one reason right there.
Old 06-26-2009, 04:16 PM   #13
my post was in response to the OP since he obviously has no clue waht he is talking about
Old 06-26-2009, 04:17 PM   #14
Old 06-26-2009, 08:44 PM   #15
s10-den's Avatar
Old 06-26-2009, 09:58 PM   #16
yes i have no clue what im talking about, after all, i did put the motor+tranny in by myself, and get it running
like i remember off the top of my head the fpi of the radiator
Old 06-27-2009, 09:26 PM   #17
that has got to be the worst argument ever.
you dont have to be the head cashier at walmart to be able to get a carbed 350/m5 combo to work.
Old 06-27-2009, 09:54 PM   #18
point?
iits good enough i asssembled the motor and put it in, as i had said before i was basing off of memory as to how many fins were there.
all i remembered was purchased from a stock car racer, 4 core copper, fits truck
Old 06-28-2009, 12:05 AM   #19
point?
my point is even a complete ****tard can put a v8 in an s10.
what is it made out of? because a copper/brass 4 core radiator is usually less efecient then a single core aluminum radiator.
Old 06-28-2009, 12:12 AM   #20
Stock Height
slonlow2000's Avatar
Old 06-28-2009, 12:16 AM   #21
we shall see how this 2 core alu radiator works in the morning after i go get a different thermostat housing
Old 06-30-2009, 06:56 PM   #22
Myself's Avatar
It will be about the same. Sounds like the only problem is, you need a fan shroud.
Old 06-30-2009, 10:42 PM   #23
Registered Neanderthal
SH-60B's Avatar
He says he has one.
The flex fan may not be able to handle enough air even in the shroud or is too deep into/ too far out of the shroud.
Old 07-01-2009, 12:00 PM   #24
Myself's Avatar
The fan blades should stick NO MORE than 1/2 way into the shroud. If too much of the blade is inside the shroud it causes too much air turbulance and won't work properly.
Old 07-02-2009, 12:14 PM   #25
yes i had a 2.8l fan shroud
i now have a 4.3 radiator and shroud along with i think its a 16" 6 blade metal fan on it, now i have yet to go over 170. if i let it sit on a 90 degree day for about 20 minutes idling it hits 190
so temp problem has been solved
Page generated in 0.62416 seconds with 31 queries
[Output: 122.93 Kb. compressed to 113.15 Kb. by saving 9.77 Kb. (7.95%)]
