350 s10 rear end - S-10 Forum
post #1 of 45 Old 04-23-2009, 11:53 PM Thread Starter
kookennay's Avatar
User is: kookennay is offline
350 s10 rear end
i got a mild 350 and built 350 turbo out of a drag truck that was a big block, it shifts hard. so what rearends are you using i read 10 bolt rear section but i wanted to see what other v-8 guys are using. i had an 86 blazer wit a built 355 and it would kill the spider gears so i welded it and that was horrible. now i got a 91 s10 and if there is any weight in the back and i get on it hard breaks the spiders when it shifts. and i t will get raced wit slicks. can i do a 9" if so what all involved in that. any help will be appreciated
post #2 of 45 Old 04-24-2009, 12:06 AM
EAT ME
88 s10 Blazer's Avatar
User is: 88 s10 Blazer is offline
Re: 350 s10 rear end
I will be getting a 9" for my 350 blazer when I get some cash. Id like to know some info on how to put it in also.
post #3 of 45 Old 04-24-2009, 12:09 AM Thread Starter
kookennay's Avatar
yeah cause i can go to pull-a-part and they got tons of 9" and eveyone around where i live say i should use a 9"
post #4 of 45 Old 04-24-2009, 02:00 AM
AWD V8's Avatar
User is: AWD V8 is offline
I've got an 8.8 Explorer I'm installing.
Limited slip & disc brakes in a package that will take you into the 10's reliably.
The rear end will likely cost you less than just a good posi.
They are wide, like for a 4X4, but you can easily shorten the longer axle tube yourself and then use 2 short axles. Wheel bolt pattern is Ford of course, that can be re-drilled for the S10.
AWD V8 is offline
post #5 of 45 Old 04-24-2009, 12:56 PM Thread Starter
kookennay's Avatar
is an 8.8 a non c-clip axle and does it have the 3rd member like an 9"
post #6 of 45 Old 04-24-2009, 05:23 PM
376ci LSX MCSS? Say what?
llorracs93s10's Avatar
User is: llorracs93s10 is offline
Send a message via AIM to llorracs93s10
im using the 8.5 rear from a 02 blazer. It comes with a few options in cluding a posi or not, and a few gear ratios like the one i have, 3.42s. And ihave a 300 hp motor, so it will withstand some powr unless ur going for big numbers.
Justin
313rwhp/337rwtq
93 S10 - 355ci lt1 - PAINTED - eagle 225's 18x8s/18x10s with 285s out back - erson 218/226 .533 ex/in lift , 02 blazer 8.5 rear --> GONE BUT NEVER FORGOTTEN!
90 obs Silverado - 5.3l swapped - 3 in. BL - 33x12.5x15s - Cragar soft 8's --> Daily
85 Monte Carlo SS --> l92/4l80e swap - In progress
Originally Posted by deadman View Post
llorracs93s10 has the baddest truck on this site...imo
post #7 of 45 Old 04-24-2009, 05:46 PM
IMBLOWN
jameskirk1's Avatar
User is: jameskirk1 is offline
be sure and get the driveshaft redone with some solid 1350 u-joints too while you're at it...
post #8 of 45 Old 04-26-2009, 06:03 PM
goin broke but n style
S15vortecpwr's Avatar
go with the 8.8 exploder rear. they are easier to find than the s-series 8.5 rear.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #9 of 45 Old 04-26-2009, 07:04 PM
ArtosDracon's Avatar
User is: ArtosDracon is offline
They are C-clip and traditional carrier, if you like the 9" for the interchangeable third member, then you have to get a 9", or a quickchange.
post #10 of 45 Old 04-26-2009, 08:53 PM
User is: Chevhead89 is offline
go with the 9". u cant beat the aftermarket support for them. im buildin one for my dime soon as i put my 383 in it.
post #11 of 45 Old 04-27-2009, 02:13 AM Thread Starter
kookennay's Avatar
wit a 9" do i have to narrow or can i find one the same width
post #12 of 45 Old 04-27-2009, 03:42 AM
you can buy custom fit 9" for the S10 from several vendors for around $900 without a center section but with the entire housing and chevy bolt pattern 31 spline axles. Check summit for direct fit housings.
post #13 of 45 Old 04-27-2009, 02:33 PM
or u can find a capable machine shop around that can shorten the housing for you. and then order custom axles from like moser or strange. or just have your old axles resplined.
post #14 of 45 Old 04-27-2009, 08:19 PM
tennerv8's Avatar
User is: tennerv8 is offline
8.8 out of an explorer. Direct bolt-in, in an s10. Thats right, zero mods to fit in an s10. I had to buy a brake line fitting for a dollar. You do have to get different offset wheels/bolt pattern. I was already getting new wheels so I don't consider that a mod to make the 8.8 go in the s10. Also an early '70's bronco ford 9". This rearend went right in one of my past v8'd s10's. I actually ditched the 9" in favor of my 8.8. My 9" was only a 28 spline axle. So for the price of an axle upgrade I got my 8.8 with a posi,disc brakes and 31 spline axles for $300 complete.
'91 s10,6.0, S475,4L80E,Circle D,ford 8.8
tennerv8 is offline
post #15 of 45 Old 04-28-2009, 09:59 PM
Another V8 Member
Alanky's Avatar
User is: Alanky is offline
Send a message via AIM to Alanky
Currie 9 inch all the way. Best thing I ever did to the truck. Takes the abuse I give it and the truck hooks great. I went through 3 stock S-10 rear ends and one well built 7.5.
1984 S-10 Sport - 406ci V8
1995 reg cab LS1 project
1999 bagged X-Cab stepside S-10 - for-sale!
Alanky is offline
post #16 of 45 Old 04-29-2009, 09:30 AM
burnt rubber's Avatar
User is: burnt rubber is offline
I'm using a 78 camaro 8.5 narrowed to s-10 specs with a strange torq-flight center section with richmond 3:42 gears and bear street axles, C-clip eliminators and bearings package. Cost a bit more than using ford stuff , but it's all GM.
ZZ4 motor, TH350 with shift kit,78 camaro 8.5 housing narrowed with strange (torq-line) diff , bear street-strip axles and c-clip eliminators and richmond 3:42 gears. Complete zq8 suspension, including hop-shock & bilstein shocks.
post #17 of 45 Old 04-29-2009, 02:27 PM Thread Starter
kookennay's Avatar
alanky how much did the currie 9" cost
post #18 of 45 Old 04-29-2009, 03:23 PM
User is: bbodycaprice is offline
I dont know if you interested or not but i have a 8.5 10 bolt with moser axles eaton gov. lock and 3.73's with c clip eliminators for sale out of my 91 s10. for 700 bucks works great. my 91 ran 7.50's 1/8th with 1.63 60' times fits great. i have some pics if your interested. 9" are amazing too though whatever route you want to go.
93 s10 402/Pglide, Dana 60, 4.56's, QA1 coil overs, 2" Drop Spindles, Backhalf/ ladderbar truck.
post #19 of 45 Old 04-29-2009, 11:10 PM Thread Starter
kookennay's Avatar
bbodycaprice i will keep that in mind cause i really looking for something i can just put in without doing alot of work like narrowing and such
post #20 of 45 Old 04-30-2009, 02:55 AM
The currie housing is listed for 964.95 on summit, the moser is 944.95, they're identically spec'ed. That is for a housing, axles, bearings and studs, they'll use stock S10 2wd wheels but require brakes designed around the late model torino housing ends with 2.5" back spacing.
Moser also sells complete 12 bolt packages that will either work with stock brakes or will come with moser/wilwood brakes installed. They are complete drop in packages that start around $2500
post #21 of 45 Old 04-30-2009, 09:07 AM
tennerv8's Avatar
Those pre-fabbed 9" rears are great if you want to throw $2k at it. Its hard to beat the value of the explorer 8.8. For $300 or less you can have a trakloc posi,3.73-4.11,31spline axles,disc brakes and 3.5" axle tubes that will go right in an s10 with some different offset wheels/bolt pattern. Don't get me wrong, if I was going all out I would pick up one of those pre-fabbed 9" rears and then build my own center section. I guess either one is a great choice just as long as you ditch that weak 7.5" ten bolt.
tennerv8 is offline
post #22 of 45 Old 04-30-2009, 10:35 AM
Another V8 Member
Alanky's Avatar
Like everybody else said. They are not cheap! I got a really good deal on mine brand new. Some guy in Fla. gave up on his project and sold everything off. Mine new was over $2500, but I didnt pay that.
Alanky is offline
post #23 of 45 Old 05-04-2009, 05:09 PM
2000 s-10zq8's Avatar
User is: 2000 s-10zq8 is offline
Send a message via AIM to 2000 s-10zq8
im running an 8.5 10 bolt with eaton posi. only one season at the track, but its holding up well. i launch about 2500 rpm with no tire spin on nitto 555r drag radials.
www.diverserides.com
post #24 of 45 Old 05-04-2009, 06:08 PM
if you are still afraid of blowing a 9inch.
Why not go rockwell. Give that a try and than you have weight on teh rear for traction. you can even get a 7.31 gear factory.
post #25 of 45 Old 05-05-2009, 02:42 AM
Ok, I LOL'ed.
post #26 of 45 Old 05-06-2009, 12:19 AM
s10 junky
wolf36520's Avatar
User is: wolf36520 is offline
Send a message via Yahoo to wolf36520
i'm using the stock 7.5 in mine with a 3.73 richmondgear on a 2 series carior (its made to fit a 2 series) with moser axles (26 spline), and a minni spool, pushing about 450 hp to it, runs 11.60s in the 1/4 and havent broke it yet, of corse its a foot brake truck but if your planning on using a trans brake i wouldnt recomend it, a ford 9 or the 8.8 would be your best bet.
make it fast, make it low, make it somthing.
post #27 of 45 Old 05-06-2009, 11:40 AM
bonedeth631's Avatar
User is: bonedeth631 is offline
what year explorer are you getting the 8.8 out of. i too blew up my 7.5 rear a couple of weeks ago it had 4.10s and the pinion just gernaded on me. and i had another 83 s10 so i took that rear out and i can feel this one really banging so ive been driving it like a old man
87 s10 blazer. 350 swap
83 s10 pickup 2.0 4 speed 4x4 for sale!
post #28 of 45 Old 05-06-2009, 11:44 AM
User is: dread is offline
go with a 8.5 10 bolt for the s-series trucks when built right they wil hold well over 450 horses and 600-650 with slicks and a direct bolt-in.
dread is offline
post #29 of 45 Old 05-06-2009, 11:59 AM Thread Starter
kookennay's Avatar
yeah i thinking about the 8.5 now my 85 monte ss had the 7.5 but i put richmond 4.10 in it wit a auburn pro series locker and it and it boke the axle tube loose and never hurt the gears or locker and it had 26 spline axles and it was way faster than my s-10 but my what do i look for to find a 8.5 is it just blazers that had them
post #30 of 45 Old 05-06-2009, 04:21 PM
capn_zr2's Avatar
User is: capn_zr2 is offline
I'm running 375hp to a stock 8.5 with 3.73:1 on 33" tires and never had a problem. factory disk brakes and a little wider than the 7.5, the only thing I dont like is the broken gov-bomb
up for some wisconsin wheeling?www.s55.photobucket.com/albums/g144/capn_zr2/
capn_zr2 is offline
post #31 of 45 Old 01-09-2011, 03:34 PM
User is: zachhern is offline
will the 8.8 explorer rearend fit in a 2nd gen? as for the 8.5 10 bolt where can i find 1 at? i need a rearend to handle the 350 im throwing in
zachhern is offline
post #32 of 45 Old 01-10-2011, 02:08 PM
jctj123's Avatar
User is: jctj123 is offline
got a gm 8.5 10 bolt works great on 305 with mild cam
jctj123 is offline
post #33 of 45 Old 01-10-2011, 02:32 PM
do u know what I could get one out of?
zachhern is offline
post #34 of 45 Old 01-10-2011, 04:30 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
The 8.8 explorer rear ends bolt into the S10. The axle tubes are 3", (bigger than the S10). The differential is offset to the passenger side by about 2", so you may have an issue with your exhaust system. The 8.5" GM rear came in the 4.3 High Output 5 speed extreme only. They were also in the Syclone and Typhoon - good luck finding one. The S10 joint in Florida was asking $950 for one on ebay. You can also use the 1999 - 2004 disc brake rear from a Jimmy/Blazer. I have one in my truck with 4.10 gears and an Eaton Posi unit. They are stout enough to handle a pretty good small block as long as you don't run slicks and a 5 speed. Check the glove box build code - G80 before the axle code is a posi. The axle codes are: GU2 = 2.73, GU4 = 3.08, GU5 = 3.23, GU6 = 3.42, GT4 = 3.73 (also GQ1), GT5 = 4.10, HC4 = 4.56 (very rare), HO4 = 4.11 (also rare). G80 before the axle code is a posi. Pre 99 rears might have the governor lock unit for the posi set up - this is not such a good unit since it slams when traction is lost on one wheel. They tend to grenade more easily.
This would probably make a good sticky...
Good luck.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best) Sold
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #35 of 45 Old 01-10-2011, 04:55 PM
http://www.vicbaggers.com
Ricky's Avatar
User is: Ricky is offline
Send a message via AIM to Ricky
I'm gonna be using a 7.5 axle w/the Torsen Zexell unit, stock shafts & gonna weld the tubes better..I hear tell that should be fine as long as I don't put slicks. Of course I won't..
I built mine for show & driving. Not racing..plus it's a truck, how well is it gonna hook up?
Thoughts?
Ricky is offline
post #36 of 45 Old 01-11-2011, 05:35 AM
Get a girdled cover for your 7.5 and it shoul dhook fine and survive some abuse.
post #37 of 45 Old 01-11-2011, 10:41 AM
User is: Gbrown2934 is offline
I found a 9 inch ford rear end on ebay to fit a S10, it was just the housing, but it was already made up to bolt right in, you need to get the 3rd member,axles etc
post #38 of 45 Old 04-05-2011, 04:58 PM
mmracing's Avatar
User is: mmracing is offline
I run a Ford 9 inch under my 1989 S10 Blazer. Best investment I made for the vehicle. You can see the part and installation at my website www.manchestermotorsportsracing.com
mmracing is offline
post #39 of 45 Old 04-05-2011, 09:13 PM
Longbeds FTMFW
gunther19820's Avatar
User is: gunther19820 is offline
I run an 8.8" in my truck. Have no issues, and it is much cheaper than a 9".
I bought/narrowed,redrilled axles/etc. for right around $350.
3.73 locker from ford. 31 spline axles, axles are also a bit over 1.25" diameter (if i remember correctly), and Ford used fcactory girdled covers on some.
http://www.s10forum.com/forum/f143/p...nto-it-490214/<---- my body drop thread
Originally Posted by aaronweisler View Post
I can one up the hummer
Originally Posted by s10xtremist View Post
By blowing bubbles before you swallow?
post #40 of 45 Old 04-07-2011, 11:35 AM
User is: smallblockTyler is offline
i have a standard ten bolt in mine coiled and locked, 350 bored .30 over with a built 400 turbo(basically the same thing) and i have had no problems but if you are really worried about it or plan on doing ALOT more to it i would just fork the money out for a 9"
post #41 of 45 Old 04-07-2011, 07:21 PM
Longbeds FTMFW
The guys aking about the Exploder Stuff...
-The tubes are 3.25", not 3".
-The spacing center to center on the spring pins is slightly different.
-You will need a conversion u-joint on 1st gens, IDK about 2nd Gens(2nd gen use a flange like the Exploder does)
-The center section is offset just about 3" to driver side.
-Exploder 8.8's are different than Ranger or Mustang units
-Exploder 8.8's were avail with lockers and open units, pop the cover to see what you are looking at
-93-98 Exploders are the one you are looking for
-93-95 were drum, 96-98 were disc.
-all axles are interchangeable.
-3.23, 3.55, 3.73 and 4.11's were available (I have never seen a 3.23 unit)
-will need brake line adapter
-they really do need to be shortened. They are 59.5" (if i remember right) from backing plate to backing plate. My stock 7.5 was 54.5" (going off memory), so I shortened the long side of the 8.8 3", and ran a second factory short-side axle.
-Ford used factory girdles under mountaineers, I believe in 98'
post #42 of 45 Old 04-07-2011, 08:28 PM
The Vehicle Dynamics Bro.
badmatt's Avatar
User is: badmatt is offline
Send a message via MSN to badmatt
Thoughts?
how about this good ricky,
calvert mono's and there bars.. I believe this truck has gone high 7's on a 275 radial.. bobby filipin i believe his name is he's on the bullet.
If your S-Series truck is V6 or V8, then your the gay that likes to give it to the other guy.
If your S-Series truck is a 4 cylinder, then your the one who likes to receive it in the ass.
RIP Neil Bursey aka Gearstix you will be greatly missed.
Project Nera:
SB2.2, 4spd dog box, FF9", Full Frame, Brembo's, and WAY to much stupidity.
LA GRAY: The shitty ZR2.... Express unit, now with 5.3
badmatt is offline
post #43 of 45 Old 04-11-2011, 11:57 AM
Ricky's Avatar
DAMN!! That is bad ass..
Ricky is offline
post #44 of 45 Old 04-11-2011, 01:50 PM
Hey guys watch this!!!
ToLows10's Avatar
User is: ToLows10 is offline
The 8.5 is the way to go. I have an 85 2dr blazers. Stock suspension, 389 cubic inch sbc making 530 hp, 350 trans with 3500 stall and transbrake, plus a bigger driveshaft. The stock 7.5 rear and driveshaft didn't make through the first burnout in the driveway. I found my 8.5 bone stock on eBay. Bolted right in, but I did have to make one hard brake line and weld the new e-brake bracket to the frame. I could have bolted it in but I like to weld. Anyway back to the strength of the rear. My blazer with the still stock 8.5, 3.42 gears( only 2 choices in an s truck 3.08 or 3.42), bf goodrich t/a radials 255/60/15 not launching off the transbrake will pull the drivers side front tire about a foot off the ground. If I launch off the transbrake I just do a massive burn out. At 65 mph my engine turns about 2700 rpm. The only reason to go with a 9" is if your gonna make Stupid amounts of power and tub out your truck. The strength of an 8.5 is comparable to a 12 bolt. And if for some reason the 8.5 fails theirs tons of parts out their to beef em up to the point where they'll run with a 9". Now 8.5's do require some special treatment. Just like an engine if it runs without oil it ain't pretty. They require gear oil made just for lockers. Hope I could be of help to someone.
I wrote that post over at blazin low late spring, early summer 2010. I have since narrowed the rear and backhalfed my blazer. Over all rear width is 38" mounting pad to mounting pad. Plenty strong. I have after market c-clip eliminator axels, 4.30 gears, full spool, all ARP fasteners, and ford big bearing housing ends. Im also running 31x18.5 Micky Thompsons on a 15" wheel. Pushing over 650hp with nitrous! The 8.5 will hold up just fine to 350-400 hp of daily abuse. Like I said before. My 100% stock 8.5" 3.42 geared locker held up to 530hp with no problems.
ToLows10 is offline
post #45 of 45 Old 06-15-2016, 11:32 AM
User is: MamaMudd7 is offline
Talking Re: 350 s10 rear end
Hello! I hope this finds you quickly as you seem to know what your talking about... hard to come by...anyway im looking to install an 8.5" posi rear in my 91' 4x4 extended cab manual s10 that I have lifted on 35's. I have cracked and twisted out the old axel and it also chewed up my drive shaft. the current gears in this are stock for a 91 (I believe 3.73s) . can I just swap out the rear axel from this 2wd 2000 truck with the posi 8.5 and change out the gears in my front axel? what kind of project am I looking at with this conversion!!! Please help I miss my truck!!
