350 69 - 79 cast number 3970010 repairable? - S-10 Forum
post #1 of 11 Old 10-26-2012, 07:02 AM Thread Starter
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
So yesterday i picked up this awesome 350 virgin block (4.00'' Bore) i could also tell it had low mileage by the absence of the raised metal at the top of the cylinders. After getting it home and having a closer inspection i found rod throw damage. Everything else checks out . Have a look below. Is it repairable? I bought this block for a 100$ bill.
Front Oil Pan Rail Pass Side
Front 2 Lower Cylinders
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered
Newest addition:
1995 Chevy S10 ext cab 4.3 Z COMPLETE 2000+ miles and counting.
post #2 of 11 Old 10-26-2012, 08:17 AM
chevy<ford's Avatar
User is: chevy<ford is offline
Re: 350 69 - 79 cast number 3970010 repairable?
As long as the crack doesnt run up the cylinder wall it should be a really easy fix. The piston doesnt actually touch that far down so it wont affect the rings at all. Regardless i do think a machine shop will sleeve it anyways just to be sure.
93 sc/sb 3.4, 2/3 drop on 20's
post #3 of 11 Old 10-26-2012, 08:45 AM Thread Starter
So i should get a magnaflux done before i even concider putting money into it? Overall its really not a bad looking block accept for the chewed up part. I want to do a 383 with this but i dont know if i should seeing the damage.
Newest addition:
post #4 of 11 Old 10-26-2012, 08:58 AM Thread Starter
i just took a closer look at the top cylinder in that picture and its either a crack or a small gouge that runs at an angle to the right but doesnt go into the ring area. So im probably looking at sleeving. lots of little gouges throughout the unused lower ring area but nothing too serious except for that pan rail chunk. Are they going to have to weld that and plane it?
Newest addition:
post #5 of 11 Old 10-26-2012, 09:03 AM
Call me Mario, Princess
AceHaag's Avatar
User is: AceHaag is offline
If you're thinking about sleeving it you might as well get another block. The 010 blocks can be had cheap.
Mike
my truck
New direction --->Time to get High
2001 s10 ext cab 6.0 243 heads, ls2 cam, nnbs truck intake, 87mm tb, 4l60e, 241c, dana 44's front and rear, 4.30 gears 35" m/t Baja claws.
AceHaag is offline
post #6 of 11 Old 10-26-2012, 09:05 AM
chevy<ford's Avatar
Possibly im thinking they might sleeve it and not **** with the crack. It doesn't look like it's as bad as it might seem.
but i'm not that knowledgable about machinging yet i know lil more then basic stuff so i can't say for sure what they will do. But that block is definetly not toast i've seen way worse on a buddy's 283 and his was fixed.
post #7 of 11 Old 10-26-2012, 09:17 AM Thread Starter
i want to get at least 350hp out of this motor, but i want at least a 8.5:1 ratio and at max a 9.0:1 ratio with a forged crank and hyper pistons. Kind of like a bulletbroof play toy.
Newest addition:
post #8 of 11 Old 10-27-2012, 10:25 AM Thread Starter
What would they do to fix the oil pan rail? I know that's not going to seal a oil pan gasket.
Newest addition:
post #9 of 11 Old 10-27-2012, 10:39 AM
User is: 02s104.3l is offline
it isn't worth the risk.. just get another block, it's not like a 010 block is rare
post #10 of 11 Old 10-29-2012, 10:40 AM Thread Starter
Just found out i cant use it, i punched out the cam bearings and the condition of them pointed toward a broke off piston. I flipped the block over and inspected the front two cylinders again and their is a huge gouge from the side of a piston right in the middle of the ring travel. Trash.
Newest addition:
post #11 of 11 Old 10-29-2012, 01:37 PM
chevy<ford's Avatar
damn u gotta wonder what the person before you did to that motor.
