305 bored over .030 what to do help!!!!!!!! - S-10 Forum
post #1 of 23 Old 02-16-2008, 12:52 AM Thread Starter
*2nd nature fabrication*
93blazer4dr's Avatar
User is: 93blazer4dr is offline
Send a message via AIM to 93blazer4dr
ok i have a 305 thats been bored over .030 and was wanting to find the best cam i can put in it. i was looking at the thumpr cams but they said it might not work because its a 305 but if it was a 350 it would. and i looked at a few other i just want a good sound dont rreally care alot of the power just want the sound and decent gas milage any of your motor guys can help me out it will be a big help.
oh yeah the guys at compcams told me it doesnt matter if the motor is bored or not that its still the same . is this true??
myspace.com--myspace.com/nachostime
click my sigVVV FOR MY PROJECT THREAD
http://www.s10forum.com/forum/f143/s...28/index6.html
what's life without a dream???
post #2 of 23 Old 02-16-2008, 01:03 AM
Hurrrr.........
Camwi_003's Avatar
User is: Camwi_003 is offline
Re: 305 bored over .030 what to do help!!!!!!!!
One, yes this is true, two, Go with the Comp 280H, its cheaper, and a great cam. Trust me on this one, you really need about 9 or 9.5 to 1 compression.
My Website (UNFINISHED!)
Member of the Anti-Bag Coalition
"Bags are for Groceries"
post #3 of 23 Old 02-16-2008, 01:09 AM Thread Starter
ok ill have to look into it. im not much of a motor person i only no tha basics but i never built a motor or anything so i dont really no much.
im wanting it to have a good sound but have it also where i can drive it everyday with out any problems.
so since the motor is bored out. it doesnt help or do much??
im going for the hot rod sound with the rough idle. i want a daily driver out of it also sorry for being random im still learning lol
post #4 of 23 Old 02-16-2008, 01:33 AM
85smallblock's Avatar
User is: 85smallblock is offline
Send a message via MSN to 85smallblock
download the comp cam engine dyno software from their website and it will ak you what your looking for and basically the one with the lower lsa will have a meaner idle.
-85' std cab sb lowered 5-6 16" GTA wheels. 295-50-16 rear 215-55-16 front, 305 tpi v8,700r4 stage 2 shift kit,tci 2000rpm stall,hedman elite shorties,jegs 2.5" true dual mandrel bent exhaust kit,
in progress............. Project Thread
SOLD
-92' TEAL BLUE s10 BLAZER 4X4 4DOOR 4.3 TBI. LOADED. GETTING LOWERED WITH 95' Z28 WHEELS SOON
post #5 of 23 Old 02-16-2008, 01:57 AM Thread Starter
ok alot of the stuf listed on there i dont understand and am not sure of what to mark.
its a stock 305 carb motor thats been bored .030 and has the stock cam in it im pretty sure so if you could help me with this that would be awsome
post #6 of 23 Old 02-16-2008, 02:00 AM
what year engine? what heads? what intake?
SOLD
post #7 of 23 Old 02-16-2008, 02:10 AM Thread Starter
1980-1985 i think the heads-stock intake-carbarated
it came out of a c10 ill have to ask my dad tomorrow he nos alot more then i do but thats all i can tell you for now
post #8 of 23 Old 02-16-2008, 02:12 AM
stuck static
lowxpectationz20's Avatar
User is: lowxpectationz20 is offline
Send a message via AIM to lowxpectationz20
you can find out your heads by pulling a number off of them under your valve cover. if you get that number and post it up, I can run the casting number and let you know what heads youve got. the casting number on the block will be back by the distributor right about where you bolt the tranny to the motor.
OldSchoolSdime92-aim
troy ohio(north of dayton)
Quote: Originally Posted by suicidedoors.com
you didnt void the warranty. at the moment i cant think of anything you can do to void the warranty.
post #9 of 23 Old 02-16-2008, 02:14 AM Thread Starter
ok ill have to get it i still got to pull the motor thanks for the help and ill try and get more into on this tomorrow
post #10 of 23 Old 02-16-2008, 02:16 AM
stuck static
no problem man, if you need anything or info on the swap shoot me a PM
post #11 of 23 Old 02-16-2008, 02:25 AM
something like the extreme energy 262h will have a mean idle and should fit stock heads with no mods
or even the high energy 268h looks like a good cam. and the 268 is even carb approved.
SOLD
post #12 of 23 Old 02-16-2008, 02:31 AM
stuck static
where you finding this? hes looking for about the same thing I am as far as a cam, but anytime i try to do somthing and say "This is all i want" i end up going more in the long run anyways
post #13 of 23 Old 02-16-2008, 02:44 AM
User is: SSBlazerV8 is offline
Just downloaded the comp cam "camquest" software. It's pretty cool. I'm going to have some fun playing with this.
post #14 of 23 Old 02-16-2008, 03:09 PM Thread Starter
i cant get any numbers off of it because its stuck out in the mud but ill do more calling around and ask them about the cam
85smallblock it says those are for an amc v8 will this work in a chevy v8 ?? sorry if its a bumd question
post #15 of 23 Old 02-16-2008, 11:14 PM
it might be the same grind but for a different engine. the amc engine is totaly different.
just look under 55-86 262-400 sbc hydraulic flat tappet cams. and check out what they have. you can eliminate many cams quickly by seeing what they operate at and what they need. also check to see how much lift you can get away with on your stock heads. you carb guys are lucky to be able to run fairly large cams on stock heads. efi is a pain in that asspect.
SOLD
post #16 of 23 Old 02-16-2008, 11:31 PM Thread Starter
ok thanks alot you have been a big help i think ill call compcams and jegs and summitracing and see what all they got to say and go from there
post #17 of 23 Old 02-18-2008, 11:21 AM
376ci LSX MCSS? Say what?
llorracs93s10's Avatar
User is: llorracs93s10 is offline
Send a message via AIM to llorracs93s10
ask what 72vega91s10 has, he has a 305 bored 0.30 over and he ran 14.2 on shitty slicks that needed to be replaced bad.
Justin
313rwhp/337rwtq
93 S10 - 355ci lt1 - PAINTED - eagle 225's 18x8s/18x10s with 285s out back - erson 218/226 .533 ex/in lift , 02 blazer 8.5 rear --> GONE BUT NEVER FORGOTTEN!
90 obs Silverado - 5.3l swapped - 3 in. BL - 33x12.5x15s - Cragar soft 8's --> Daily
85 Monte Carlo SS --> l92/4l80e swap - In progress
Originally Posted by deadman View Post
llorracs93s10 has the baddest truck on this site...imo
post #18 of 23 Old 02-18-2008, 04:21 PM Thread Starter
will do thanks for the help guys and the truck is still stuck in the mub and now i got the flu
but how do i get ahold of him or how do i look him up on here ?? i put the sn in the search but it came up with nothing
post #19 of 23 Old 02-18-2008, 11:30 PM
72Vega_91S-10 put this in the sn part of the search. he also has a thread in the v8 section that you can look up to get his sn.
Justin
313rwhp/337rwtq
post #20 of 23 Old 02-19-2008, 09:31 AM
LSx and V8 Mod
SweetS10V8's Avatar
User is: SweetS10V8 is offline
Send a message via AIM to SweetS10V8
Exactly, its not even worth talking about. All it does is say you had cylinder walls that needed cleaned up. People like to use it like a punch line, such as "4 bolt main" or "160* T-stat". All which dont really matter in most cases. Some people are also just stupid when they go from a standard bore to the maximun bore just to try to eek a few cubic inches out of the engine.
Think about it, if your engine needs to go .020 over and you take it .060 over just for the heck of it, you just missed at least two more rounds of rebuilds that the block was good for.
For the love of God, dont go around calling your 305 a 310 since its .030 over, its still a 305.
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
post #21 of 23 Old 02-19-2008, 03:15 PM
Trust Me
The Griff's Avatar
User is: The Griff is offline
quoted
post #22 of 23 Old 02-19-2008, 09:27 PM
L98 Blazer
j_slezak187's Avatar
User is: j_slezak187 is offline
Send a message via AIM to j_slezak187
im no engine builder, but it seems to me that a 262 grind or so would be plenty for a stock motor. pardon the pun, but the hot cam all the L03 guys on TGO are using is the LT1 cam. however, this is only for roller motors.
-'87 S10 Blazer, 355 TPI/700R4
-'02 ZR2 Daily Driver
my CarDomain
post #23 of 23 Old 02-19-2008, 10:31 PM
CHANGE YOUR EMAIL ADDRESS
User is: ezrollin is offline
The biggest cam I'd use in a street driven 305 would be a comp's 268 or crane 272 a 280 in a 305 wouldn't be fun on the street. What you need is at minmum is the 305 4bbl heads or a set of 305 vortec heads will have the right combution chamber cc and remember don't use over 1.94 intake valves or they will hit,don't use 350 heads. It won't make power without good heads no matter what cam you us.
ezrollin is offline
