2.2 to v8 swap - S-10 Forum
post #1 of 4 Old 02-20-2010, 11:18 AM Thread Starter
User is: johna20376 is offline
2.2 to v8 swap
Considering buying an 1997 s10 with a blown 2.2. Body is in perfect shape and truck is selling cheap. Its an automatic. My question is I thought about buying this and my son and I make it a project and put a v8 in it. I haven't done this for years. Anyone have any good advice?
this would be a daily driver and we would not be in a big hurry to get it done.
Thanks
post #2 of 4 Old 02-20-2010, 02:36 PM
User is: slammeds1077 is offline
Re: 2.2 to v8 swap
I am just about to finish up a 97 with a 2.2 and a 5 speed to a carbed 355 with a turbo350 auto. What are your plans? Carb or fuel injection? Transmission? The auto in it now will not bolt up to a small block so you will nee a different one. I used a turbo 350 with a 9" tailshaft and was lucky enough that my driveshaft will still work. I believe the 700R4 is similar in length but it has overdrive. Just let me know what questions you have and i'll help as much as I can.
post #3 of 4 Old 02-20-2010, 02:49 PM Thread Starter
Re: 2.2 to v8 swap
Thanks for reply. Thats what I'm trying too figure out . Carb or injected. Not sure which one would be the easier of the two. It will be an automatic definately. Are there pros and cons between carb and injected?
Thanks
post #4 of 4 Old 02-20-2010, 11:40 PM
Re: 2.2 to v8 swap
Pros to carb is that its quick and easy to get hooked up and running. Pros to fuel injection is once its hooked up its gonna start without trouble no matter what conditions your in once its tuned properly and it will be more efficiecient for fuel mileage possibly. I ran carb cause it was quick and there is far less wiring to work on. I would like to build an injected truck later on but for now i'm content with running carbs.
