14102193 ? - S-10 Forum
post #1 of 20 Old 08-29-2005, 06:01 PM Thread Starter
PPG sprayin' member
downtoearth's Avatar
User is: downtoearth is offline
14102193 ?
I just got back from the junkyard with the 14102193 vortec heads, I couldn't find any 906's or 062's so I settled for these, but all I can find on them is that they are either 305 or 350 heads with 1.94-1.50's. Is there anyway to distiguish between 305 and 350 heads. Also will these flow the same as the 906's and 062's? Thanks
-Mitch
post #2 of 20 Old 08-29-2005, 07:22 PM
i dont have feelings
Cronos's Avatar
User is: Cronos is offline
Re: 14102193 ?
193 casting is the tbi 350
the diff between 305 and 350 is the gap between the chambers, also intake valves on 305 are 1.880"
Cronos is offline
post #3 of 20 Old 08-29-2005, 07:44 PM
LSx and V8 Mod
SweetS10V8's Avatar
User is: SweetS10V8 is offline
Send a message via AIM to SweetS10V8
Re: 14102193 ?
I dont think those are Vortec heads, Vortecs came out much later than 1987
14102193...87-up...305/350......1.94"/1.5" valves
The "gap between the chambers" is the same on a 350 and a 305. Basically its the 58cc combustion chamber(on 305 heads) vs 64-76cc chambers on 350 heads, with slightly different runners sizes.
If they are TBI heads, they wont flow for crap!
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
post #4 of 20 Old 08-29-2005, 11:46 PM Thread Starter
PPG sprayin' member
Re: 14102193 ?
They are vortecs, centbolt valve covers and the 8-bolt intake. Came off a 97 TBI chevy truck. Why wont they flow for crap if they are TBI, I thought the 906's and 062's were the best once you can get, and they both came of TBI vehicles.
-Mitch
post #5 of 20 Old 08-30-2005, 12:38 AM
Vortec 350 s10
91sdime's Avatar
User is: 91sdime is offline
Re: 14102193 ?
Vortec engines used a CPI with a plastic upper intake and a spider injector setup.
Are you sure about that casting number...From what I understand, there are only 3 different casting numbers..
10239906 - the head to avoid due to the pressed in exhaust seat which kills flow in the low-mid range of valve lifr
12558060/12558062 - The desirable heads. The 060 cast number is the actual first casting, and can be turned into either the 062 or 906 dependant of application. If it retains the 060 casting number, then it has a few minor cosmetic differences from the 062, but the flow rates are identical. The 906 head wasnt a long produced head though.
This is from info I gathered while doing my Vortec build up, so I cant vouch for total accuracy, but I can vouch that the casting number you have is NOT a vortec head.
Religion is a bandage created by man to heal a soul made bloody by circumstance
92 S10 - 355 SBC/TH350 trans...something always breaks..damn money pit
There is no such thing as a stupid question, just inquisitive idiots.
91sdime is offline
post #6 of 20 Old 08-30-2005, 12:49 AM Thread Starter
PPG sprayin' member
Re: 14102193 ?
I know for a fact it is a Vortec Head, GM never produced a centerbolt, 8-bolt intake head that wasn't a vortec.
-Mitch
post #7 of 20 Old 08-30-2005, 01:06 AM
Cronos's Avatar
Re: 14102193 ?
alright, a vortect head or not....forget casting numbers does it have an egr crossover? no vortec heads EVER had a crossover
and sweet, i work with cylinder heads for a living, the gap between chambers on a 305 is different than a 350. also, 305 didnt come with 1.94 intake valves
Cronos is offline
post #8 of 20 Old 08-30-2005, 01:55 AM
Vortec 350 s10
91sdime's Avatar
Re: 14102193 ?
Also, if you look on the head in the front, there should be 3 triangles if it is a true vortec head.
I didnt say the head you have isnt a vortec, just the casting number you posted up.
Better yet..[click here
91sdime is offline
post #9 of 20 Old 08-30-2005, 08:43 AM
Cronos's Avatar
Re: 14102193 ?
beautiful! the 062 had the 3 triangles the 906 has a round lump
Cronos is offline
post #10 of 20 Old 08-30-2005, 11:32 AM
pursuit S10's Avatar
User is: pursuit S10 is offline
Send a message via AIM to pursuit S10 Send a message via Yahoo to pursuit S10
Re: 14102193 ?
You've got that backwards. 062 had the 3 triangles and 906 has the hump. Other than that I agree with everything you said. lol
We've got one of each out in the shop so i could double check..
Here's the 520 305 vortec casting mark
As far as I know there are only 3 different Vortec v8 casting numbers:520 (305) 062,906 (350)
'02 Blazer 2dr 2wd 5speed
'82 S10 383ci
post #11 of 20 Old 08-30-2005, 07:32 PM
Cronos's Avatar
Re: 14102193 ?
backwards?? huh....
i built two sets of 906 that have the hump...
you know what i did find out? one set had factory seats, the other set did not. this was the first set of 906s that ive seen without seats
im thinkin that this guy got some heads that someone converted the intake studs on. we have a kit at work for it, bolts on the intake side and you drill and tap the new holes for the vortec intake
Cronos is offline
post #12 of 20 Old 08-30-2005, 07:37 PM
Re: 14102193 ?
The 906 in my picture is doesn't either.
Who knows..
Something funky is goin on.
'82 S10 383ci
post #13 of 20 Old 08-30-2005, 10:47 PM
LSx and V8 Mod
SweetS10V8's Avatar
Re: 14102193 ?
Its possible they could be refered to as a vortec head, but they are definatly not the same "Vortec" head everyone wants.....
And you also wouldnt want to go on telling people you have Vortec heads, because people now days are educated enough to know what to look for and will know your lying, because the term Vortec head refers to one that makes more power and has a 906 or 062 casting number.
So for all intents and purposes, you do not have what people refer to as Vortec heads
post #14 of 20 Old 08-30-2005, 11:54 PM
Re: 14102193 ?
Back when Vortec heads were not legal at our local dirt track the stupid ass no nothing tech man almost ate fist when he accused one driver of having Vortecs.
They were just regular ol POS Tbi heads.
'82 S10 383ci
post #15 of 20 Old 08-31-2005, 12:04 AM
Cronos's Avatar
Re: 14102193 ?
hey!! not all TBIs suck!! my heads are very similar to vortec heads! theyre 083s
Cronos is offline
post #16 of 20 Old 08-31-2005, 12:59 AM Thread Starter
PPG sprayin' member
Re: 14102193 ?
Ok f*ck it, these heads blow, I am gonna trade my buddy these for a set of 906's or 062's, he's got plety of them laying around.
-Mitch
post #17 of 20 Old 08-31-2005, 04:38 PM Thread Starter
PPG sprayin' member
Re: 14102193 ?
GOOD NEWS!!!...I think, I went to his shop today to see if he wanted to trade, he replied with I give ya a better deal, he whips out a newly machined set of corvette aluminum heads, all I have to do is put the valves, springs, etc in. BUT, they are angle spark plug heads, can I run these with small tube headmans? God I hope so! I will have pics tommorrow for ya!
-Mitch
post #18 of 20 Old 08-31-2005, 11:21 PM
11 second station wagon
The Stunningman's Avatar
User is: The Stunningman is offline
Re: 14102193 ?
Corvette heads were shi@t. My buddy had a choice between a set of aluminum corvette
heads(centerbolt) and vortecs The vortecs were the lump type with the hardened exh.
seat. well the vortecs fowed 229 intake the vette heads flowed 190. even after porting
(he picked the vette heads for weight savings) they didn't outflow the vortecs. The exh.
side would've been another story the vortecs flowed 140's (poor) cause of the seat.
post #19 of 20 Old 09-01-2005, 06:44 AM
LSx and V8 Mod
SweetS10V8's Avatar
Re: 14102193 ?
That maybe true, but people will still pay $500 for a good set of #113 aluminum vette heads
post #20 of 20 Old 09-01-2005, 10:47 AM
Re: 14102193 ?
I looked for this post before but couldn't find it until now.
http://forums.s-series.org/viewtopic.php?t=33406
'82 S10 383ci
